> Probably irrelevant at this point, but I screwed up, I meant: > > `ls -l /var | grep lock` lrwxrwxrwx 1 root root 9 Aug 5 2014 lock -> /run/lock > I don't see a USB adapter in there, was it plugged in when you did the `ls`? Not using a USB adapter. Mobo has a traditonal serial port.
