[vcf-midatlantic] ADTPro help
Christopher Blackmon
ckblackm at yahoo.com
Tue May 24 16:27:38 EDT 2016
Evan,
Given what I've seen on fb... you really should just do a 64 bit install of a currentLinux version so that you're not trying to mix and match 32 and 64 bit libraries/programs/stuff.Besides, you won't be able to access all of your 16gb of ram at once w/ a 32 bit install.
Christopher.
From: Evan Koblentz via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org>
To: vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org>
Cc: Evan Koblentz <evan at snarc.net>
Sent: Tuesday, May 24, 2016 4:09 PM
Subject: Re: [vcf-midatlantic] ADTPro help
> Probably irrelevant at this point, but I screwed up, I meant:
> `ls -l /var | grep lock`
lrwxrwxrwx 1 root root 9 Aug 5 2014 lock -> /run/lock
> I don't see a USB adapter in there, was it plugged in when you did the `ls`?
Not using a USB adapter. Mobo has a traditonal serial port.
