[vcf-midatlantic] ADTPro help
Evan Koblentz evan at snarc.net
Tue May 24 16:35:54 EDT 2016
> Evan,
> Given what I've seen on fb... you really should just do a 64 bit install of a currentLinux version so that you're not trying to mix and match 32 and 64 bit libraries/programs/stuff.Besides, you won't be able to access all of your 16gb of ram at once w/ a 32 bit install.
Yeah I just discovered the memory issue a little while ago. Had no idea!
Was hoping to avoid all that work, but it looks like I've gotta go for it.
