[vcf-midatlantic] Good source for eproms?
Dave Wade dave.g4ugm at gmail.com
Wed May 25 07:38:35 EDT 2016
It is in the UK but I am not too sure if its differs from an imperial
assload or if a US Imperial assload is different from a UK imperial assload.
Judging by the shorts sported by some US tourists recently observed at a
museum in the UK , unlike pints, the US version is larger.
G4UGM
p.s. If any one over this side needs proms I have a few, and can program
some of the more common variety.
> -----Original Message-----
> From: vcf-midatlantic [mailto:vcf-midatlantic-
> bounces at lists.vintagecomputerfederation.org] On Behalf Of chrisjpf33---
via
> vcf-midatlantic
> Sent: 25 May 2016 12:30
> To: vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org>
> Cc: chrisjpf33 at gmail.com
> Subject: Re: [vcf-midatlantic] Good source for eproms?
> Is "metric assload" am official Department of Weights and Measures unit of
> measurement?
> On May 24, 2016, at 11:54 PM, Dave McGuire via vcf-midatlantic <vcf-
> midatlantic at lists.vintagecomputerfederation.org> wrote:
>  Yes.  The problem with EPROMs forgetting their contents is charge leakage
> from the floating gates, not chip failure.
>  I have a metric assload of EPROMs (literally thousands) of nearly every
type,
> especially the really common ones like 2764s, if anyone needs them.
>              -Dave
> > On 05/24/2016 11:52 PM, Ian Primus via vcf-midatlantic wrote:
> > Even if an EPROM has gotten corrupted, the chip itself should still be
> > fine. Just erase and reprogram. I've yet to have a problem with doing
> > this, it's quite rare to have a dead EPROM.
> > Almost every EPROM I have has been scavenged from some sort of junk
> > board or another. 2764's and 2732's are quite common, should not be
> > hard to find.
> > -Ian
> > On Tue, May 24, 2016 at 11:22 PM, Jason Perkins via vcf-midatlantic
> > <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> >> I'm trying to get a Plus HardCard going again. Like many the ROM has
> >> forgotten some of its bits so I want to try installing a freshly
> >> flashed one.
> >> What's a good source for 7264s? Is it worth trying to get used ones
> >> on eBay? While I'm at it I'd like to track down a 2732 for an Apple
> >> ProFile formatting rom.
> >> Thanks,
> >> Jason Perkins
> Dave McGuire, AK4HZ
> New Kensington, PA
