[vcf-midatlantic] Robots and Relays and Commodore
Chris Fala chrisjpf33 at gmail.com
Wed May 25 13:47:34 EDT 2016
On Wed, May 25, 2016 at 12:58 PM, Dan Roganti via vcf-midatlantic <
> On Wed, May 25, 2016 at 12:31 PM, Chris Fala via vcf-midatlantic <
> > Would this help?
> > http://www.ebay.com/itm/152084733487
> ​almost,
> that one has 6 outputs
> you need one with 10 outputs​
Thought the C64 user port only had an 8-bit port. Where are the other two
connected? The VIC has a few of the joystick port connected to the user
port, but not sure what other outputs you can get out of the C64.
