[vcf-midatlantic] Robots and Relays and Commodore
Dan Roganti ragooman at gmail.com
Thu May 26 13:27:16 EDT 2016
On Thu, May 26, 2016 at 12:44 PM, Chris Fala via vcf-midatlantic <
> On Thu, May 26, 2016 at 12:41 PM, Douglas Crawford via vcf-midatlantic <
> > You guys prefer the posts over the loops on the back of the connectors?
> I prefer the loops, helps to hold wires in place as you solder them. I
> imagine that if you need to solder to a circuit board, the posts would be
> better.
​yea, I prefer posts when using a prototype board.
When you have a double sided copper prototype board,
you can use each row of pins as an anchor,
one row soldered on top and the other row soldered on the bottom
This helps make it rugged enough for a prototype
Just as with DB connectors
Now a right angle connector would be ideal,
but you have to take what you can get sometimes with the supply.
On the User Port enclosures,
I think Hammond might have a good option,
Looking there soon
Dan
