[vcf-midatlantic] other museum TV options: Roku box
Systems Glitch systems.glitch at gmail.com
Tue Nov 1 11:56:57 EDT 2016
> The trouble with Pi is the can corrupt their boot disk...
As stated though, you can knock that out with a read-only root FS (what I do on most embedded systems) or a small battery backup. I've seen several Li-Ion based UPS boards (hats? plates? shields? I don't know what they're called) for the Raspberry Pi that, along with either a script or a kernel driver, will gracefully shut the Pi down when either the battery is low or just whenever main power has been offline for a predetermined time.
I think someone already mentioned it would be cool to get IXR to help and do something for the VCFED blog about it.
Thanks,
Jonathan
