[vcf-midatlantic] other museum TV options: Roku box
Dave Wade
dave.g4ugm at gmail.com
Tue Nov 1 13:44:30 EDT 2016
> -----Original Message-----
> From: vcf-midatlantic [mailto:vcf-midatlantic-
> bounces at lists.vintagecomputerfederation.org] On Behalf Of Systems Glitch
> via vcf-midatlantic
> Sent: 01 November 2016 16:57
> To: vcf-midatlantic at lists.vintagecomputerfederation.org
> Cc: Systems Glitch <systems.glitch at gmail.com>
> Subject: Re: [vcf-midatlantic] other museum TV options: Roku box
> > The trouble with Pi is the can corrupt their boot disk...
> As stated though, you can knock that out with a read-only root FS (what I
do
> on most embedded systems) or a small battery backup. I've seen several Li-
> Ion based UPS boards (hats? plates? shields? I don't know what they're
> called) for the Raspberry Pi that, along with either a script or a kernel
driver,
> will gracefully shut the Pi down when either the battery is low or just
> whenever main power has been offline for a predetermined time.
> I think someone already mentioned it would be cool to get IXR to help and
do
> something for the VCFED blog about it.
> Thanks,
> Jonathan
But of course if you use a device that's designed for streaming like the
Amazon Firestick all you have to do is plug it in the HDMI port and you can
play....
