[vcf-midatlantic] Museum network
David Riley fraveydank at gmail.com
Mon Nov 28 22:27:33 EST 2016
> On Nov 28, 2016, at 8:16 PM, Jonathan Gevaryahu via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> On 11/28/2016 4:01 PM, Systems Glitch via vcf-midatlantic wrote:
>>  unless it's*really*  poorly behaved 10baseT.
> I.e. Asante Nubus cards which fail to properly query/broadcast their network type/etc? I have to run those behind their own tiny 10baseT hub to connect to the network at all...
FWIW, a 10Base-T switch should work fine in those situations, though they're relatively rare compared to 10/100 or gigabit switches.  It's not the switch to which the embuggered Ethernet device objects (and I have a few Mac Ethernet cards of the above-described type with that problem), it's the negotiate.
If you can manually set the port speed, that's good, otherwise, you can force it by putting a hub/bridge/switch in between to force it to 10.
- Dave
-------------- next part --------------
A non-text attachment was scrubbed...
Type: application/pgp-signature
Desc: Message signed with OpenPGP using GPGMail
URL: <https://lists.vcfed.org/pipermail/vcf-midatlantic/attachments/20161128/c2e06b73/attachment.sig>
