[vcf-midatlantic] Museum network
Martin Flynn maflynn at theflynn.org
Tue Nov 29 13:50:29 EST 2016
Have the 10GB blades for it as well....
> On Nov 29, 2016, at 1:30 PM, Neil Cherry via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> On 11/29/2016 01:05 PM, Systems Glitch via vcf-midatlantic wrote:
>>> I don't know that we have much data to protect (or target!) but what does the
>>> hive-mind here think about it? A firewall is generally good to have; would this one
>>> suit us?
>> All computing resources should be protected, there's no excuse for zero protection
>> nowadays.
> Afraid, Kernel Sanders? ;-)
> Actually it is this 'it's not important' attitude that causes way too much problems
> for those work with such things. I'll stop now as this could be a very long rant.
>> You've clearly not heard the 1U screamers I'm talking about -- it's a high pitched,
>> extremely annoying and LOUD sound. It penetrated the 4 wythe brick walls that separated
>> our server room from the storage area in front of it. You'll know something is going
>> on, but you won't want to be anywhere around it!
> How about 26 Cisco 7600's fully loaded and dual power supplies?
> Martin donated a 6500 (same as the 7600 basically) that could handle
> your switching/routing needs (and then some). I think we need to wait
> a bit longer before we can really put it to work. There currently isn't
> enough of a load to work with it.
> Linux Home Automation         Neil Cherry       ncherry at linuxha.com
> http://www.linuxha.com/                         Main site
> http://linuxha.blogspot.com/                    My HA Blog
> Author of:        Linux Smart Homes For Dummies
