[vcf-midatlantic] Museum network
Dean Notarnicola
dnotarnicola at gmail.com
Tue Nov 29 14:06:08 EST 2016
Agreed! UPnP is disabled (always!). It has an SPI firewall ( I beleive, I
will doubled check)
I check the firmware revision when I'm in the museum. Maybe we should
create a maintenance schedule for the router.
On Tue, Nov 29, 2016 at 1:46 PM Systems Glitch via vcf-midatlantic <
> > Excellent points. Dean says the switch has plenty of protection itself.
> Thoughts?
> Dean says the *router* has protection, that's very different :) I don't
> know what sort of router you guys are using, but as long as it's kept
> up-to-date, UPnP is disabled, and there's a sane default-deny firewall in
> place, it's probably fine.
> Thanks,
> Jonathan
