[vcf-midatlantic] ISO: DECServer 550 Power Cord
Martin Flynn
maflynn at theflynn.org
Thu Oct 6 15:14:12 EDT 2016
Google c15 connector - if that's what you need I can drop off Saturday am with the rack side panels
> On Oct 6, 2016, at 2:52 PM, Systems Glitch via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> In another case of, "the right way, the wrong way, and the DEC way," it seems there's a special IEC cable used for DECServer 550s. Does anyone have one? It looks like a regular grounded IEC cable, but with a groove cut in the plug, opposite the ground pin. Looks like I could probably make do with a Dremel tool and a standard cable, but I thought I'd check first.
> Thanks,
> Jonathan
