[vcf-midatlantic] ISO: DECServer 550 Power Cord
Dave Wade dave.g4ugm at gmail.com
Thu Oct 6 15:14:17 EDT 2016
Its actually standard, the high temperature version of the normal IEC
connector. It is rated to 120 degrees Celsius rather that 70 as the normal
lead....
.. in the UK we call them Kettle Leads as they are commonly used on
kettles...
https://en.wikipedia.org/wiki/IEC_60320
G4UGM
> -----Original Message-----
> From: vcf-midatlantic [mailto:vcf-midatlantic-
> bounces at lists.vintagecomputerfederation.org] On Behalf Of Systems Glitch
> via vcf-midatlantic
> Sent: 06 October 2016 19:53
> To: vcf-midatlantic at lists.vintagecomputerfederation.org
> Cc: Systems Glitch <systems.glitch at gmail.com>
> Subject: [vcf-midatlantic] ISO: DECServer 550 Power Cord
> In another case of, "the right way, the wrong way, and the DEC way," it
> seems there's a special IEC cable used for DECServer 550s. Does anyone
have
> one? It looks like a regular grounded IEC cable, but with a groove cut in
the
> plug, opposite the ground pin. Looks like I could probably make do with a
> Dremel tool and a standard cable, but I thought I'd check first.
> Thanks,
> Jonathan
