[vcf-midatlantic] ISO: DECServer 550 Power Cord
David Riley
fraveydank at gmail.com
Thu Oct 6 15:26:58 EDT 2016
> On Oct 6, 2016, at 3:24 PM, Dave McGuire via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> On 10/06/2016 02:52 PM, Systems Glitch via vcf-midatlantic wrote:
>> In another case of, "the right way, the wrong way, and the DEC way,"
>> it seems there's a special IEC cable used for DECServer 550s. Does
>> anyone have one? It looks like a regular grounded IEC cable, but with
>> a groove cut in the plug, opposite the ground pin. Looks like I could
>> probably make do with a Dremel tool and a standard cable, but I
>> thought I'd check first.
> ...and the right way that one doesn't understand, and thus assumes was
> a bad idea. ;) *poke*
> They're standard IEC320-C15 connectors, which are the high-temperature
> version of the very common (without the notch) IEC320-C13.
> Large Cisco switches and routers, as well as some SGI equipment
> (Origin 2000 comes to mind) use the next size up, the 20A-rated IEC320-C20.
Also, percolators. Mine came with such a cord, though the socket on the pot doesn't enforce it.
The high-temp cords don't melt/deform at high temperatures, which is a serious safety concern for servers and coffee pots.
- Dave
-------------- next part --------------
A non-text attachment was scrubbed...
Type: application/pgp-signature
Desc: Message signed with OpenPGP using GPGMail
URL: <https://lists.vcfed.org/pipermail/vcf-midatlantic/attachments/20161006/5688a573/attachment.sig>
