[vcf-midatlantic] VCFed BBS finally happening
Joseph Oprysko joprysko1 at gmail.com
Wed Oct 12 15:42:46 EDT 2016
Chris, once we have the GSM SIM card setup in the system, dialing into the
BBS from the real world via a modem should be possible. Likely at no speeds
faster than 2400, as the cellular networks are optimized for voice calls,
and modem calls often have issues, especially at higher speeds.
On Wednesday, October 12, 2016, Christopher Gioconda via vcf-midatlantic <
> This brought a huge smile to my face, since BBS'ing was what got me into
> this whole fantastic world of vintage computing.
> Evan, if one has a 1200 baud modem and would like to dial in from home,
> would that be supported, or will it only be internal in the VCF building?
> Chris
> On Wed, Oct 12, 2016 at 2:13 PM, Evan Koblentz via vcf-midatlantic <
> vcf-midatlantic at lists.vintagecomputerfederation.org <javascript:;>> wrote:
> > Everyone,
> > We've had various talk / starts / stops about an authentic-ish dial-up
> BBS
> > through the years. Now it is finally coming true.
> > The most recent plan was to use Asterisk, but that is overkill, a lot of
> > maintenance, and would require an expensive telephony card. I asked Joe
> O.
> > to research something better. He came back with this:
> > http://www.excelltel.com/en/enproductslist.asp?id=612
> > It's an 8-port analog PBX with a GSM module. We bought it on Amazon for
> > $98.49.
> > Joe will connect this via modem to a PC running MajorBBS (possibly
> > virtualized). We'll connect modems and vintage computers to the analog
> > ports. Visitors and VCF East exhibitors/visitors will be able to dial in
> at
> > 300-2400bps, hear the handshake, and connect to our BBS just like in the
> > glory days. People can also telnet in directly to the PC thanks to our
> LTE
> > modem, or they can call in remotely once we buy a GSM SIM card (to be
> > considered after the main system is up and running).
> > The PBX won't arrive until sometime next month because it shipping from
> > China.
> > Joe suggested that someone can draw the standard VCFed logo using ASCII
> > art, and BBS users can watch it fly by a line at a time when they
> connect.
> > I endorse that idea!
> > Joe will answer any technical questions. Keep in mind we selected this
> > approach because it's affordable, low maintenance, and the simplest way
> to
> > reach the goal. Some people wanted us to use all period hardware, or
> modern
> > servers that were WAY more than we needed, or a high-end PBX, etc. ....
> > this one is "just right" for us.
Normal Person: Hey, it seems that you know a lot.
Geek: To be honest, it's due to all the surfing I do.
Normal Person: So you go surfing?
Normal Person: But I don't think that has anything to do with knowing a
lot...
Geek: I think that's wrong on a fundamental level.
Normal Person: Huh? Huh? What?
