[vcf-midatlantic] Looking for a TI Silent 707 1200baud for the VCF Museum
David Williams dave at willomail.co.uk
Fri Oct 14 11:54:24 EDT 2016
On 14/10/2016 15:00, Neil Cherry wrote:
> On 10/14/2016 09:46 AM, David Williams via vcf-midatlantic wrote:
>> Just tried dumping a text file to my 703 at 1200 baud and you're
>> right, after about 500
>> characters or so, it can't keep up with the input. Is there any way
>> to put a delay after
>> characters / line on Simh? I tested again by dumping the same text
>> file via TeraTerm using
>> a 15ms delay per character and 350ms per line and it seemed to work
>> fine.
> Don't the RS232 control leads take care of this?
They should but I don't believe they are present of the RPi board
