[vcf-midatlantic] TVs installed!
Christopher Gioconda cgioconda at gmail.com
Sun Oct 23 19:34:04 EDT 2016
Hi Evan!
This is fantastic! Great job!
I know content is the next item you're going to work on, but how will the
content be directed to the TVs? Do you plan to have the same content on
both TVs simultaneously or some kind of a slideshow that would loop?
The reason I ask is that I've played around with devices that convert HDMI
cables to Ethernet for long distances (100+ ft) since HDMI has signal
degradation at that length. Monoprice sells them
http://www.monoprice.com/mobile/product/details/6532?gclid=CjwKEAjwv7HABRCSxfrjkJPnrWgSJAA45qA2FBGmQASAMjqIwainlXC1KbczSd7nhQqG3dR97n2uFhoCIx3w_wcB
I'd be happy to help any way I can.
Chris
On Oct 23, 2016 3:26 PM, "Evan Koblentz via vcf-midatlantic" <
> Anthony B. drove down to the museum from Westchester County NY yesterday.
> We spent all day installing the TVs and wire conduit to hide the cords
> because we weren't about to dig into the walls.
> It turned out great! Anthony had the idea to paint the tops of the
> mounting hardware white so it blends into the ceiling color.
> Here are some pictures.
> The TVs are lightweight so the hardware just screws into studs, no lag
> bolts needed: www.vcfed.org/evan/before.jpg
> Before and after painting the posts: www.vcfed.org/evan/after.jpg and
> www.vcfed.org/evan/drill.jpg
> Anthony tried escaping into the attic, but I caught him:
> www.vcfed.org/evan/attic.jpg
> The results: www.vcfed.org/evan/room.jpg and www.vcfed.org/evan/hall.jpg
> Next project: content!
