[vcf-midatlantic] TVs installed!
Neil Cherry ncherry at linuxha.com
Mon Oct 24 09:24:06 EDT 2016
On 10/24/2016 08:38 AM, Dan Roganti via vcf-midatlantic wrote:
> ​​that was my original point
> Plus the RPi is small enough to attach to the back of the ​TV ​
> using a case and double sided tape
There are proper mounts that can be used (but a good tape will work)
> Saving you an unnecessary long hdmi cable, or usb cable
> I would think there's an extra outlet in the attic to power this.
> And you can easily connect a wireless keybd​/mouse
> ​S​o you can change anything or manually operate the media player
> You could add a WiFi connection too so then you can remotely add content
You can steal USB power from the USB port :-)
You can put WiFi on it then you can access the Pi with SSH. Just
another option. I wouldn't recommend fighting with the Pi Zero. Just
get e Pi 3 and you will find it quite usable. If you turn off, or
reconfigure the logging and a few other things you can use NFS or
CIFS for the media. I'm doing this with the Atari 8 bit disk drives
(the Pi emulates a disk drive). I'll demonstrate that at Festivus.
Linux Home Automation         Neil Cherry       ncherry at linuxha.com
http://www.linuxha.com/                         Main site
http://linuxha.blogspot.com/                    My HA Blog
Author of:    	Linux Smart Homes For Dummies
