[vcf-midatlantic] TVs installed!
Neil Cherry ncherry at linuxha.com
Mon Oct 24 11:51:15 EDT 2016
On 10/24/2016 11:32 AM, Dan Roganti via vcf-midatlantic wrote:
> On Mon, Oct 24, 2016 at 11:23 AM, Evan Koblentz via vcf-midatlantic <
> vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> After all the comments, here's how I see this working: connect the Pi (or
>> any appropriate microcontroller) to the TV via HDMI so we can get power
>> from the USB port. There aren't outlets in the ceiling/attack and it would
>> save us money on cabling. Then use WiFi or Bluetooth to wirelessly connect
>> the Pi(s) to our network.
> ​Then where do you plug in the TV,
> if there's only a single outlet, couldn't you add a multi outlet adapter,
> to give you 3 outlets​
> It's not safe to power off without a shutdown on the RPi, if the TV's usb
> port shuts off, just as with any Linux system.
> People do it anyway, when they unplug the adapter on the RPi, but they are
> just lucky till their SD card get scrogged
> Dan
Dan it can be done, if we can setup the SD read only, turn off swap
and any application that write to the SD (such as syslog). When we
need to write the SD (for configuration) we can remount the SD as
write.
Linux Home Automation         Neil Cherry       ncherry at linuxha.com
http://www.linuxha.com/                         Main site
http://linuxha.blogspot.com/                    My HA Blog
Author of:    	Linux Smart Homes For Dummies
