[vcf-midatlantic] TVs installed!
Corey Cohen
AppleCorey at optonline.net
Mon Oct 24 12:27:42 EDT 2016
I have noticed PI only seem to corrupt class 10 cards when you shut off the AC. If you shut off the 5v DC like what would happen when the TV is turned off, they seem fine.
So rule #1 with the PI, don't power off by turning off the power strip.
Cheers,
Corey
corey cohen
uǝɥoɔ ʎǝɹoɔ
> On Oct 24, 2016, at 10:51 AM, Neil Cherry via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> On 10/24/2016 11:32 AM, Dan Roganti via vcf-midatlantic wrote:
>> On Mon, Oct 24, 2016 at 11:23 AM, Evan Koblentz via vcf-midatlantic <
>>> After all the comments, here's how I see this working: connect the Pi (or
>>> any appropriate microcontroller) to the TV via HDMI so we can get power
>>> from the USB port. There aren't outlets in the ceiling/attack and it would
>>> save us money on cabling. Then use WiFi or Bluetooth to wirelessly connect
>>> the Pi(s) to our network.
>> Then where do you plug in the TV,
>> if there's only a single outlet, couldn't you add a multi outlet adapter,
>> to give you 3 outlets
>> It's not safe to power off without a shutdown on the RPi, if the TV's usb
>> port shuts off, just as with any Linux system.
>> People do it anyway, when they unplug the adapter on the RPi, but they are
>> just lucky till their SD card get scrogged
>> Dan
> Dan it can be done, if we can setup the SD read only, turn off swap
> and any application that write to the SD (such as syslog). When we
> need to write the SD (for configuration) we can remount the SD as
> write.
> Linux Home Automation Neil Cherry ncherry at linuxha.com
> http://www.linuxha.com/ Main site
> http://linuxha.blogspot.com/ My HA Blog
> Author of: Linux Smart Homes For Dummies
