[vcf-midatlantic] TVs installed!
David Riley
fraveydank at gmail.com
Mon Oct 24 12:41:27 EDT 2016
On Oct 24, 2016, at 11:51 AM, Neil Cherry via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> It's not safe to power off without a shutdown on the RPi, if the TV's usb
>> port shuts off, just as with any Linux system.
>> People do it anyway, when they unplug the adapter on the RPi, but they are
>> just lucky till their SD card get scrogged
>> Dan
> Dan it can be done, if we can setup the SD read only, turn off swap
> and any application that write to the SD (such as syslog). When we
> need to write the SD (for configuration) we can remount the SD as
> write.
Yes, this is the correct way to do it. I do it all the time for things like routers. It's considerably easier to do on something like OpenBSD than on modern Linux (because most modern Linux distributions like to have a lot of different read/write directories for systemd and the like), but it's still pretty doable with tmpfs overlays and periodic syncs to flash (just use a journaled filesystem and hope you're not syncing when the power goes out).
Updating the content is then another matter, but I highly recommend NFS for that purpose (rather than trying to swap out physical media). Connect your signage via Ethernet if you know what's good for you.
- Dave
-------------- next part --------------
A non-text attachment was scrubbed...
Type: application/pgp-signature
Desc: Message signed with OpenPGP using GPGMail
URL: <https://lists.vcfed.org/pipermail/vcf-midatlantic/attachments/20161024/251e3c3f/attachment.sig>
