[vcf-midatlantic] Lego Logo 9767 Apple II Interface Build
Systems Glitch
systems.glitch at gmail.com
Tue Sep 13 08:55:14 EDT 2016
Full Writeup: http://www.glitchwrks.com/2016/09/12/lego-logo-interface
Ian was going to build the interface, but since I ended up having to troubleshoot the suspected flakey hardware after The Eleventh HOPE, I went ahead and built one to have a known-good board to test with. This uses one of the new Apple II protoboards I laid out a few months ago. I may either reduce the hole size or increase the annular ring on the pads. Right now you can stuff two 24 AWG solid wires plus a socket pin in the holes, which is great for point-to-point prototyping. It'll also take a through-hole switch or 2 Watt resistor without drilling out.
About to run out to the post office and send it on its way to Evan!
Thanks,
Jonathan
