[vcf-midatlantic] Last call for those coming to workshop 9/17 & 9/18
J. Alexander Jacocks
jjacocks at gmail.com
Fri Sep 16 10:24:28 EDT 2016
Herb,
I've got an SE/30 with an unknown issue, manifested by no beep/no boot.
The tube is good, and the voltages on the analog board are good, so I'm
pretty sure that it's the logic board, which I did have to clean some
corrosion off of.
So, I could use an undamaged case (mine has a broken corner), and a
known-good logic board.
Thanks!
- Alex
On Thursday, September 15, 2016, Todd George via vcf-midatlantic <
> > XX) Lost count. I'm 90% sure I'm coming at least saturday. May bring
> > TRS-80 M3 or 4 and H-500 with broken clock generator - Need 5000uf
> 10v-ish
> > caps, axial I suspect. ESR meter is on the way, but probably won't make
> it
> > to the show.
> > So some junk drawer caps and and ESR would be helpful.
> I'll definitely have my ESR meter. I'm low on ~5000uf caps, I need a few
> for my one Macintosh. Will be ordering them, but won't have them in time
> for the workshop due to lack of planning.
> See ya!
> -Todd
