[vcf-midatlantic] Last call for those coming to workshop 9/17 & 9/18
Tony Bogan thebogans at mac.com
Fri Sep 16 11:02:19 EDT 2016
> On Sep 16, 2016, at 10:24 AM, J. Alexander Jacocks via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> Herb,
> I've got an SE/30 with an unknown issue, manifested by no beep/no boot.
> The tube is good, and the voltages on the analog board are good, so I'm
> pretty sure that it's the logic board, which I did have to clean some
> corrosion off of.
> So, I could use an undamaged case (mine has a broken corner), and a
> known-good logic board.
> Thanks!
> - Alex
> On Thursday, September 15, 2016, Todd George via vcf-midatlantic <
>>> XX) Lost count.  I'm 90% sure I'm coming at least saturday.  May bring
>>> TRS-80 M3 or 4 and H-500 with broken clock generator - Need 5000uf
>> 10v-ish
>>> caps, axial I suspect.  ESR meter is on the way, but probably won't make
>> it
>>> to the show.
>>> So some junk drawer caps and and ESR would be helpful.
>> I'll definitely have my ESR meter.  I'm low on ~5000uf caps, I need a few
>> for my one Macintosh.  Will be ordering them, but won't have them in time
>> for the workshop due to lack of planning.
>> See ya!
>> -Todd
Alex, I have five or six SE/30s that go from working to nonworking and some in between. I'm not going to be at the workshop but I'd gladly bring you up what you need. I can stop by Saturday probably some time in the morning (I'm working Saturday evening and all day Sunday)
Feel free to contact me on or off list and we will work it out.
Tony
