[vcf-midatlantic] the binary programmer cartoon
Dave McGuire
mcguire at neurotica.com
Wed Aug 9 16:47:23 EDT 2017
On 08/09/2017 08:20 AM, Dan Roganti via vcf-midatlantic wrote:
> On Wed, Aug 9, 2017 at 8:04 AM, Evan Koblentz via vcf-midatlantic <
> vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> LOL ... learning the fundamentals of the HP-1000 and PDP-8 front panels,
>>>> and starting to learn assembly, has been a real eye-opener for me. Mostly
>>>> it's confirmed my existing belief that you guys are all very smart and/or
>>>> very crazy. :)
>>> For your next stupid human trick.. err I mean eye opener, you need to
>>> design your own CPU at a register transfer level out of either standard
>>> logic families (74xx/4xxx) or discrete transistors like Eric. Then after
>>> that you need to build your own transistor from raw Earth materials. Then
>>> we can let you into the super secret engineering rooms... where things
>>> REALLY get crazy!
>> I'll get right on that.
> and then you have to build a 1-bit CPU,
> where all operations are done in serial fashion,
> not the customary 8-bit parallel [or 16-bit,32-bit,etc]
> That's another terminology which has faded from history,
> These days, when you mention the phrase "parallel computer",
> it refers to multiple processors operating together, in a cohesive fashion.
> If you recall some of the systems from the past history,
> that earlier terminology about serial computers was commonplace,
> and it was done mostly to save money on components,
> But always at the expense of performance.
> So you can't go wrong with making only 1-bit CPU ;)
It is often forgotten that parallelism can be implemented at many
different levels in computing.
-Dave
Dave McGuire, AK4HZ
New Kensington, PA
