[vcf-midatlantic] using catweasel to format an RX01
Ian Primus
ian.primus.ccmp at gmail.com
Thu Aug 10 06:50:12 EDT 2017
Yes - it has to be single density. Just about any CP/M system with 8"
disks should be able to format single density ones. The IBM 3740
format was kind of the standard interchange format - a lowest common
denominator that most systems could handle. There is an XXDP utility
that can be used to update such disks to RX02 format - requires an
RX02, of course. I do not believe there is anything to go the other
way. The DEC RX02 format is special and weird. It uses the same base
single density formatting, using single density sector headers with
double density data areas. As such, really nothing else can create it.
My method for creating RX02 media has been to format blank disks as
single density on something else, then use the XXDP util to update
them to RX02.
I'm sure you can format RX01 disks with a Catweasel, I just have no
idea how this is done. I don't have a Catweasel and have never seen
one. You can, however, use ImageDisk and a compatible PC controller to
format single density disks - which is a method I've used to get RX01
blanks as well.
-Ian
On Wed, Aug 9, 2017 at 11:59 PM, william degnan via vcf-midatlantic
<vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> As long as it's single density though. Right? Not sure if I have a cp/m
> system w/ single density 8" drives. I'll have to check. Thanks for the
> tip. Of anyone going to then workshop has any I will trade rx01 for rx02.
> i have a lot of tx02's
> On Aug 9, 2017 10:04 PM, "Ian Primus via vcf-midatlantic" <
>> If you have any CP/M machine that uses 8" disks, you can use that to
>> format blank RX01 media. It's just IBM 3740 SSSD - at least, in the
>> low level. Then you can do the high level formatting on the DEC
>> machine.
>> -Ian
>> On Wed, Aug 9, 2017 at 8:43 PM, william degnan via vcf-midatlantic
>> > Anyone ever formated an 8" disk to be used in an RX01 using a catweasel
>> > controller? Curious if it's worth trying this route. I have a Tandon
> 848
>> > drive.
>> > Bill
