[vcf-midatlantic] Mac SE coming to Workshop
Jason Perkins
perkins.jason at gmail.com
Fri Aug 11 12:58:14 EDT 2017
Probably a miniscribe drive... if the heads aren't suck to the platters, it
most likely needs a low level format.
-J
On Fri, Aug 11, 2017 at 11:34 AM, william degnan via vcf-midatlantic <
> I am picking up a MAC SE model 5011 with a bad SCSi HD (I am told) on the
> way to the workshop Saturday to play around with. Not sure if anyone is
> into these I think the hard drive is bad because it needs a new Apple
> sticker on the side. I have found if you replace the sticker the computer
> fixes itself.
Jason Perkins
313 355 0085
