[vcf-midatlantic] Mac SE coming to Workshop
J. Alexander Jacocks
jjacocks at gmail.com
Fri Aug 11 14:40:40 EDT 2017
Dean,
Believe it or not, several of the manufacturers had the "controlled drop"
as a recommendation, in their drive service guides. This really only
applied to the early drives, though. I've never had to do it on a drive
manufactured after 1985.
- Alex
On Fri, Aug 11, 2017 at 2:29 PM, Dean Notarnicola via vcf-midatlantic <
> Never drop them! Sticktion can (usually) safely be fixed by placing the
> drive on a smooth surface, rapidly rotating it a few times with a flick of
> the wrist, then quickly applying power. Dropping risks head damage.
> The only time this did not work for me, I had to sacrifice the drive by
> opening it and spinning the platters manually. The drive was absolutely on
> borrowed time from that point on, but I managed to recover the data. Does
> not bother using it after that.
> On Fri, Aug 11, 2017 at 1:54 PM Adam Michlin via vcf-midatlantic <
> > Certain early brand new SE hard drives (I want to say Quantum 40s and
> > 80s, but my memory is fuzzy) were prone to so-called "stiction" even
> > back in the day when they were new. Back in the day we would drop the
> > computer from a few inches and often fix them.
> > My understanding is that if that works these days your drive is on
> > borrowed time (maybe even back then!).
> > On 8/11/2017 1:42 PM, Jeffrey Brace via vcf-midatlantic wrote:
> > > I'm interested in compact macs. I have an SE/30 that I used in college
> > and
> > > loved the machine!
> > > Besides replacing the sticker, I also found that kicking computers
> helps
> > > too. Sometimes these old machines are just grouch old computers. If in
> > > doubt kick it!
> > > On Fri, Aug 11, 2017 at 11:34 AM, william degnan via vcf-midatlantic <
> > >> I am picking up a MAC SE model 5011 with a bad SCSi HD (I am told) on
> > the
> > >> way to the workshop Saturday to play around with. Not sure if anyone
> is
> > >> into these I think the hard drive is bad because it needs a new Apple
> > >> sticker on the side. I have found if you replace the sticker the
> > computer
> > >> fixes itself.
