[vcf-midatlantic] Simple 3D Printable case for WiFi232
John Heritage
john.heritage at gmail.com
Wed Aug 16 18:09:00 EDT 2017
I made a very simple 'slide in' sleeve case for the WiFi232 modem in case
anyone is interested. It does not fully enclose, but at least keeps the
electronics off of your desk surface, and leaves plenty of room for the USB
and RS232 connectors, and to push the button. The plastic does cover the
solder in point for power, but the sketchup file is there if you need to
change it. ~ 827mm of 3.0mm plastic required.
https://www.thingiverse.com/thing:2486879
