[vcf-midatlantic] Simple 3D Printable case for WiFi232
william degnan
billdegnan at gmail.com
Wed Aug 16 19:26:07 EDT 2017
purty
On Wed, Aug 16, 2017 at 6:09 PM, John Heritage via vcf-midatlantic <
> I made a very simple 'slide in' sleeve case for the WiFi232 modem in case
> anyone is interested. It does not fully enclose, but at least keeps the
> electronics off of your desk surface, and leaves plenty of room for the USB
> and RS232 connectors, and to push the button. The plastic does cover the
> solder in point for power, but the sketchup file is there if you need to
> change it. ~ 827mm of 3.0mm plastic required.
> https://www.thingiverse.com/thing:2486879
