[vcf-midatlantic] OT: Solar Eclipse sunglasses -- legit, better and still cheap
systems_glitch
systems.glitch at gmail.com
Thu Aug 17 09:16:45 EDT 2017
Heh, don't know that I'd trust a Harmful Freight device with my eyesight,
but there are many other suppliers that will carry name-brand eye
protection. The goggle type devices are often called "cutting glasses" or
"cutting goggles" because they're only used when cutting or welding with an
oxy-fuel torch -- electric arc welding requires full face protection from
the UV given off by the arc as it'll sunburn any exposed skin. Many big box
hardware stores carry either Lincoln, Hobart, or Miller branded safety
gear, which is fine, safe stuff.
We went in for new glasses last week, and the optometrist had cardboard and
film filter glasses for free in their lobby.
Thanks,
Jonathan
On Thu, Aug 17, 2017 at 8:22 AM, Dan Roganti via vcf-midatlantic <
> On Thu, Aug 17, 2017 at 7:52 AM, Dan Roganti <ragooman at gmail.com> wrote:
> > This is a better option and it doesn't cost much, only $6
> > its not the gimmicky stuff that you see sold in stores,
> > and its the same material specified for welding masks to filter the solar
> > light.
> > It's the same specification used by astronomers for their telescope
> > equipment
> > but these are welding goggles, so it's light weight and costs less,
> > These are found at Harbor Freight and other places with tools
> > pass it on
> > https://www.harborfreight.com/welding/welding-helmets/2-
> > piece-welding-goggles-set-35712.html
> > <https://www.google.com/url?q=https%3A%2F%2Fwww.
> harborfreight.com%2Fwelding%2Fwelding-helmets%2F2-piece-
> welding-goggles-set-35712.html&sa=D&sntz=1&usg=
> AFQjCNFPbNNUpb5KMLVsW65ZYez-XMLOuQ>
> FYI,
> The ANSI Z87.1.1989 spec [American] and the ISO 12312-2 spec
> [International] are basically the same eye-wear safety spec
> They both specify the same requirements for the solar filters
> _ ____
> / \__/ Scotty, We Need More Power !!
> \_/ _\__ Aye, Cap'n, but we've only got 80 col's !!
