[vcf-midatlantic] Monitor needed for museum
Ian Primus
ian.primus.ccmp at gmail.com
Sun Aug 20 01:21:24 EDT 2017
But you already have multiple HDMI displays in the museum? I'm not
sure what more you need?
On Sun, Aug 20, 2017 at 1:08 AM, Evan Koblentz via vcf-midatlantic
<vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> Rule#1
>> get it working first, ie, connect standard LCD monitor[1080] using the
>> generic settings it >already< has
>> Rule#2
>> fix your remote login, etc, etc, etc on a nice happy looking #$#%@ LCD
>> monitor with 1080
>> Rule#3
>> Then, make changes to fit your location,
>> ie small monitor for your rack
>> Note: need linux tech support help
> You're entirely missing the point.
> Pi was working fine.
> It still does work fine, in that it's functioning correctly as a file server
> to the tablets.
> Bill Dudley knows Unix/Linux as well as anyone I've ever met.
> However he found that he was suddenly unable to remotely log in the other
> day.
> Thus we need to connect a display directly to the Pi.
> We could spend a bunch of time trying to get a VGA working with it, or we
> could just get the right monitor in the first place -- one with an HDMI
> input.
