[vcf-midatlantic] Monitor needed for museum
Ian Primus
ian.primus.ccmp at gmail.com
Sun Aug 20 01:26:41 EDT 2017
Right, kind of inconvenient, but you can use one of them to fix the
problem you're having, then configure the resolutions so that you can
use the regular monitor you already have, or set it to use a serial
console. Ideally, the pi would run and do it's thing without *ever*
needing a monitor.
On Sun, Aug 20, 2017 at 1:24 AM, Evan Koblentz via vcf-midatlantic
<vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> But you already have multiple HDMI displays in the museum? I'm not
>> sure what more you need?
> We have one mounted to the museum ceiling and another mounted to the hallway
> ceiling.
> Those are both 32" and not exactly in convenient locations for this purpose.
> We need a smaller one that would live inside the rack.
