[vcf-midatlantic] Monitor needed for museum
Jim Scheef
js at sdf.org
Mon Aug 21 11:50:01 EDT 2017
I know you guys are way smarter than this, but why not remove the Pi from
the rack, take it to the required monitor (and keyboard, and return it
when fixed? Since it isn't working anyway, no one will miss it. when it is
working, it will be apparent (on the same network), and you can move it
back. The reboot will prove it is fixed and all this will well - or am I
missing something?
This must be are more complicated that I immagined.
Jim
On Sun, 20 Aug 2017, Ian Primus via vcf-midatlantic wrote:
> Date: Sun, 20 Aug 2017 01:26:41 -0400
> From: Ian Primus via vcf-midatlantic
> <vcf-midatlantic at lists.vintagecomputerfederation.org>
> To: vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org>
> Cc: Ian Primus <ian.primus.ccmp at gmail.com>
> Subject: Re: [vcf-midatlantic] Monitor needed for museum
> Right, kind of inconvenient, but you can use one of them to fix the
> problem you're having, then configure the resolutions so that you can
> use the regular monitor you already have, or set it to use a serial
> console. Ideally, the pi would run and do it's thing without *ever*
> needing a monitor.
> On Sun, Aug 20, 2017 at 1:24 AM, Evan Koblentz via vcf-midatlantic
> <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>>> But you already have multiple HDMI displays in the museum? I'm not
>>> sure what more you need?
>> We have one mounted to the museum ceiling and another mounted to the hallway
>> ceiling.
>> Those are both 32" and not exactly in convenient locations for this purpose.
>> We need a smaller one that would live inside the rack.
js at sdf.org
SDF Public Access UNIX System - http://sdf.lonestar.org
