[vcf-midatlantic] OT: Pi RCA conversion
Evan Koblentz
evan at vcfed.org
Tue Aug 22 00:30:17 EDT 2017
> The center pin wire (white insulated) is the video signal the outer conductor (shield/bare wire) is the ground.
> Since a video signal is a complex high frequency AC Signal there is no positive or negative. A standard NTSC or EIA/RS-170 signal in consumer equipment in the US is 1V PP.
Okay.
The picture in the link I posted shows the pin labeled TV reversed from
the Pi in front of me. Anyhow, it seems pretty clear that video signal
wire goes to the TV pin and the ground goes to its neighbor.
I'll give this a try.
