[vcf-midatlantic] Monitor needed for museum
Evan Koblentz evan at vcfed.org
Tue Aug 22 00:36:01 EDT 2017
> I stumbled on this tidbit in Pi-for-newbies site: "The TV pads allow you
> to connect an RCA jack to the board instead of using the HDMI out."
> Hmmmmmmm.....
> That sounds helpful at home and at the museum too.
Continuing to think aloud: the big monitor already installed above our
workbench has composite input. I know it works because I tested it with
a Laser 128 not long ago. Unlike the HDMI monitor on the museum ceiling
(facing the door), the composite monitor in the workshop can be
comfortably viewed from anywhere. Plus a long RCA cable is something I
have laying around, vs. buying a long HDMI cable. :)
