[vcf-midatlantic] FS: Prototype Glitch Works Ohio Scientific Universal RAM Board
systems_glitch
systems.glitch at gmail.com
Wed Aug 23 15:55:21 EDT 2017
link: http://www.ebay.com/itm/272817996082
I'm selling some of the prototype boards for my GW-OSI-RAM1 Universal 128
KW RAM board. This board provides up to 128 KW (64 KW without memory
management) of static RAM on the Ohio Scientific bus. It supports a 12-bit
word size and is compatible with the Ohio Scientific 560Z "Processor Lab"
in PDP-8 mode. It also includes a prototyping area, and a header for
mezzanine display boards. Included with the auction is a Hex Lamp Register
and an Octal Lamp Register, which can be mounted directly to the
GW-OSI-RAM1 or used remote on a cable (e.g. for a front panel).
This is a pre-production board, the most significant difference is that it
lacks a corner mounting hole, which can be drilled if needed (no circuit
traces run under its location). The other differences are minor. See
auction link for full description!
Thanks,
Jonathan
