[vcf-midatlantic] FS: Industrial 486 ISA Computer with 8 GB DOM, Ethernet, MS-DOS 6.22, Utils
systems_glitch
systems.glitch at gmail.com
Thu Aug 24 15:20:57 EDT 2017
On Herb's recommendation, I ran TESTFDC, a companion utility to ImageDisk,
and discovered that the floppy controller onboard the SBC can handle
single-density as well as double-density with 128 byte sectors at all data
rates. So, this would make a very nice little machine for imaging/writing
out old soft sector disks!
Thanks again, Herb, for prompting me to run TESTFDC!
Thanks,
Jonathan
On Wed, Aug 23, 2017 at 7:30 PM, systems_glitch <systems.glitch at gmail.com>
wrote:
> Description + pictures on the VC Forums:
> http://www.vcfed.org/forum/showthread.php?59315-FS-
> Industrial-486-ISA-Computer-with-8-GB-DOM-Ethernet-MS-DOS-6-22-Utils
> This little box started life as an 8-port terminal and application server.
> It came to me with only the CPU board, and a crashed hard disk that looked
> like it had a plain DOS install on it anyway. I cleaned it up as described
> in the forum thread, but I'm thinking I'll sell it as my PICMG box is
> effectively the same thing but more flexible.
> Thanks,
> Jonathan
