[vcf-midatlantic] vintage comms days
william degnan
billdegnan at gmail.com
Fri Feb 3 21:58:41 EST 2017
degnanco.net, the background bubbles effect, is built using processing.js
On Fri, Feb 3, 2017 at 8:39 PM, Dan Roganti via vcf-midatlantic <
> On Fri, Feb 3, 2017 at 8:22 PM, Dan Roganti <ragooman at gmail.com> wrote:
> >> might I suggest another flavor of Java, it's called Processing,
> > with a strong suite of libraries in almost every category
> > and the compiler runs on the 3 major platforms
> > it's brought many people from other fields to programming
> > using a cohesive form of the language
> > https://processing.org/
> btw,
> another helpful tidbit,
> you don't need 3 platforms to build it for any user platform
> any platform will create builds for all 3 platforms
> not sure if this was included with the original Java compiler
> so I would upload all three builds and anyone can download it
> just wanted to point this out
> Dan
