[vcf-midatlantic] vintage comms days
Neil Cherry ncherry at linuxha.com
Fri Feb 3 22:20:05 EST 2017
On 02/03/2017 08:22 PM, Dan Roganti via vcf-midatlantic wrote:
> On Fri, Feb 3, 2017 at 8:01 PM, David Gesswein via vcf-midatlantic <
> vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
>> On Fri, Feb 03, 2017 at 07:40:09PM -0500, william degnan via
>>>> My PDP-8 is available all the time. http://www.pdp8online.com/run.
>> shtml
>>>> Alas the interface is Java which has gone from the hot new thing when I
>>>> originally did it to obsolete in browsers. Will have to figure out how
>>>> to redo it when I get time.
>>> Just curious, what is the issue?
>> On Fri, Feb 03, 2017 at 07:45:06PM -0500, Dan Roganti wrote:
>>> ???oh I remember yours Dave
>>> But didn't you mean javascript
>>> I noticed this doesn't work anymore on Chrome ver.45 and later
>>> But other browsers still do
>>> I think having a Java app instead would be ideal,
>>> it's still cross platform, and no need for browsers
>>> Dan
>> Its a Java browser app, not javascript. The problem is due to the security
>> issues with java browsers are making it harder and harder to run java in
>> the
>> browser and many people don't have the plugin installed. At some point
>> only signed apps are going to be supported. If it wasn't dying in the
>> browser
>> I could purchase yearly the code signing cert.
> ​might I suggest another flavor of Java, it's called Processing​,
> https://processing.org/
I didn't know that was a superset of Java but the issue still remains.
Most browser are blocking any Java (that means the JVM) so you can't
even run Processing.
Linux Home Automation         Neil Cherry       ncherry at linuxha.com
http://www.linuxha.com/                         Main site
http://linuxha.blogspot.com/                    My HA Blog
Author of:    	Linux Smart Homes For Dummies
