[vcf-midatlantic] vintage comms days
Dan Roganti ragooman at gmail.com
Fri Feb 3 23:37:00 EST 2017
On Fri, Feb 3, 2017 at 10:27 PM, Neil Cherry via vcf-midatlantic <
> On 02/03/2017 10:20 PM, Neil Cherry via vcf-midatlantic wrote:
>> On 02/03/2017 08:22 PM, Dan Roganti via vcf-midatlantic wrote:
> ​might I suggest another flavor of Java, it's called Processing​,
>> https://processing.org/
>> I didn't know that was a superset of Java but the issue still remains.
>> Most browser are blocking any Java (that means the JVM) so you can't
>> even run Processing.
> I spoke too soon, sorry (just read it also support JS).
​yea, the one Deganan mentioned
processingjs works with html5 browsers,
which I just found out works in nearly every browser, if not all of them
the first one I mentioned, processing
is just another flavor of java, not javascript or applet
so thats just another executable you can run in the cli
Dan
