[vcf-midatlantic] Ideas needed: attaching our tablets to shelf poles
Martin A Flynn maflynn at theflynn.org
Mon Feb 6 18:35:01 EST 2017
On 2/6/2017 6:10 PM, Evan Koblentz via vcf-midatlantic wrote:
>> What's the budget per unit, and would you be adverse to using epoxy to
>> fasten the brackets directly to the aluminum back shell of the Flex 8
> Ahem: "Some folks suggested attaching U-clamps directly to the back of
> the tablets, but that is permanent-ish. I don't want to do that."
> The tablets are $50 and we could spend maybe 25-ish max per mounting
> system.
Flat steel plate with two of these on the back:
https://www.dxengineering.com/parts/dxe-rsb-i10000 to clamp to the rack post
Use industrial Velcro to fasten the tablet to the steel plate. The low
budget really constrains what can be done....
