[vcf-midatlantic] Ideas needed: attaching our tablets to shelf poles
Jonathan Gevaryahu
jgevaryahu at gmail.com
Mon Feb 6 18:35:32 EST 2017
On 2/6/2017 6:10 PM, Evan Koblentz via vcf-midatlantic wrote:
>> What's the budget per unit, and would you be adverse to using epoxy to
>> fasten the brackets directly to the aluminum back shell of the Flex 8
> Ahem: "Some folks suggested attaching U-clamps directly to the back of
> the tablets, but that is permanent-ish. I don't want to do that."
> The tablets are $50 and we could spend maybe 25-ish max per mounting
> system.
double sided 3m foam mounting tape, and/or maybe some sort of wood or
metal backing plate with edge clamps which hold the tablet in place? I
have no idea how much that would cost...
Jonathan Gevaryahu
jgevaryahu at hotmail.com
