[vcf-midatlantic] Ideas needed: attaching our tablets to shelf poles
Herb Johnson
hjohnson at retrotechnology.info
Sun Feb 12 14:34:03 EST 2017
I read today this thread, about attaching tablets near the exhibits. My
impressions of Evan's requirements are: ASAP, keep tablet secure from
theft, "look slick", zero to a few tens of dollars to mount, provide
visitor access to screen/touch.
I also suggest: tablet access to people of varying height or physical
access. Vision limited people may need to hold it close. Youngsters are
often short. Persons in wheelchairs. I have a plan B for these.
The simplest ASAP means to secure the tablets, is a plastic-covered
metal rope, looped or locked at the tablet, bolted at the display shelf.
Most tablets have a loop for this purpose, or one could be epoxied on.
This is not "slick" but can at least look professional. I own
institutional Macs from the 90's which were secured in this way. it's
relatively cheap. And, if a better solution is found, these can be
removed and discarded. Wire rope is at Home Depot, Lowes, etc. by the
foot, in various colors and clear.
Plan B for more a accessible solution: a loaner tablet, with all the
exhibit apps, and a means of navigating them. Not "secure"? Ask to hold
a driver's license, a standard request for loaned items. Need I explain
this?
Herb
