[vcf-midatlantic] Workshop February 11&12, 2017 Wrap-up
Douglas Crawford touchetek at gmail.com
Mon Feb 13 16:56:38 EST 2017
On 2/13/2017 4:29 PM, Brian Schenkenberger via vcf-midatlantic wrote:
> Douglas Crawford via vcf-midatlantic writes:
> {deleted much HTML shite}
>> Where do u get them!?
> The DS1287A was fairly common TOY clock back then.  You can replace it with
> the newer DS12887A.  Goggle it, there are ample sources.
12887s yes of course.   I thought you meant there were actual
replacement 1287A's now available.
12887A's don't work in some applications.  They don't work in GRiDs
reportedly.
Which is the only one I've bothered trying to replace.
