[vcf-midatlantic] Wifi232
william degnan billdegnan at gmail.com
Fri Jun 2 14:43:23 EDT 2017
Yes.  Here is a link to a few photos of my wifi232 in action:
http://vintagecomputer.net/browse_thread.cfm?id=685
The only issue I've run into so far is with hardware control.  The
kit/assembled unit does not have a jumper installed to toggle on/off
hardware control, you'd have to add one in but the documentation shows you
were to add the jumper.  Hardware control is required for things like the
DECwriter II.  I was able to get Wifi232 to work with most anything that
did not use hardware control i.e. standard 8-bit computers, DEC Rainbow,
DEC 220/241, IBM PC and so on.
I have been using a CHIP SBC use for the same basic purpose as the
WIFI232.  The CHIP provides the back-end of a computer but does not provide
AT commands as the interactions.  It's nice to have both I guess.    What's
nice about the WIFI232 is that you don't have to spend a lot of time
setting up a CHIP or Raspberry Pi to get what wifi232 gives you out of the
box.  The Wifi232 also has a nice built-in web server that allows a person
to make changes to the "modem" settings remotely while plugged into the
device directly.  I plan to use the WIFI232 regularly.
Bill
On Fri, Jun 2, 2017 at 2:24 PM, John Heritage via vcf-midatlantic <
> Hey I'm watching a video review of the Wifi232 modem - I wasn't aware of
> this product until today.  I assume you got the pre-assembled kit?   Still
> enjoying this device?
> On Tue, May 23, 2017 at 6:59 PM, william degnan via vcf-midatlantic <
> > Yesterday I got one of Paul Rickard ' s WIFI232 devices and I should say,
> > Well Done!  It's perfect for vintage computing.  Plunk one on most any
> > serial port and you're all set.  Great documentation and features too.
> > There is even a built-in wifi access server function.
> > I tested on a vt240 last night to connect to telnet bbs and other telnet
> > sites
> > ATDT towel.blinkenlights.nl [enter]
> > ATDT IP address of BBS
> > Etc.
> > http://biosrhythm.com/?page_id=1453
> > Bill Degnan
> > twitter: billdeg
> > vintagecomputer.net
