[vcf-midatlantic] Weekend workshop report
Mike Loewen mloewen at cpumagic.scol.pa.us
Sun Jun 11 22:46:23 EDT 2017
    I worked on two projects at the museum, this weekend: my recently
acquired Eagle IIE micro and the museum's HP 2117F display system.  The
Eagle is a 4MHZ Z80 system (CP/M) with 64KB RAM and SS 5-1/4" drives.  The
display was out of adjustment, with a "doubled" presentation.  A quick
tweak by Ian on one of the video pots fixed that, and I resoldered the
leads to the reset switch which had been inexplicably cut by a former
owner.  Nice bright and clear display (green CRT), passes internal diags.
    The HP 2117F is a circa 1983 mini, with a hardware floating point
processor module.  I pulled the power supply and checked the inside of the
top cover for the infamous black form: yep.  It hadn't quite started to
disintegrate, but it was just a matter of time.  I removed the foam and
glued a plastic shield in its place.  The power supply voltages were
close, but I adjusted them to spec.
    The system wasn't completing its self-test, and didn't seem to be
recognizing its RAM.  It turned out to be a missing ribbon cable which is
supposed to connect the RAM boards (3 boards of 256KW each) to the
controller board.  I pulled a donor cable from our ugly 2113E hangar queen
and the memory tests now pass.  I also replaced 3 broken plastic toggles
on the front panel with parts from the 2113E.  I showed Evan how to toggle
in a short program from the front panel to make the lights dance, Cylon
style.  To paraphrase a line from the movie, "Firefox": you MUST think in
octal.  :-)
    The 2117F is missing a couple of crucial controller cards to connect to
the peripherals in the cabinet: the HP-IB interface for the hard disc, the
7970B tape drive interface, and the interface for the 13037C disc
controller.  Fortunately, the 2113E has the requisite HP-IB card (12821A)
so it may be possible to check out the HP-IB drive in the future.
Old Technology				http://q7.neurotica.com/Oldtech/
