[vcf-midatlantic] WiFi RS-232 Internet Modem
Paul Rickards rickards at gmail.com
Sun Jun 18 10:46:33 EDT 2017
W2HX- It does have a TCP server built in so you telnet to it. Port defaults
to 6400 but you can change it. To the serial side, it appears as a dialup
modem is connected. When the you telnet to it, the "phone is ringing" and
will it send a "RING" response. You answer it by issuing a "ATA" command or
you can enable auto answer (ATS0=1) and it will connect automatically.
If you need it to be more transparent to the serial side (i.e. will a
"RING" and "CONNECT" message confuse the PDP?) you can turn off responses
with ATQ0.
It doesn't support the full set of RS-232 signals like DTR, DSR, RI, DCD,
etc. I'm not sure if the PDP needs those signals to know there's a device
there or not. There are jumpers on the bottom of the WiFi232 for certain
RS-232 signals so you can loop those back to the host to get around most
requirements.
Cheers,
-p
On Sun, Jun 18, 2017 at 10:32 AM, W2HX via vcf-midatlantic <
> Question on this device... Can it be used to connect to the console port
> on a machines (ie PDP-8e) and allow me to telnet to the PDP over wifi? Does
> it have telnet server to serial functionality? Thanks
> -----Original Message-----
> From: vcf-midatlantic [mailto:vcf-midatlantic-bounces at lists.
> vintagecomputerfederation.org] On Behalf Of Paul Rickards via
> vcf-midatlantic
> Sent: Sunday, June 18, 2017 9:33 AM
> To: vcf-midatlantic
> Cc: Paul Rickards
> Subject: Re: [vcf-midatlantic] WiFi RS-232 Internet Modem
> As promised, I'm alerting folks on the list that more WiFi232 modems are
> available (both assembled and kits).
> http://biosrhythm.com/?page_id=1453
> I'll announce it later today on Twitter (it will likely sell out shortly
> after).
> Cheers,
> -p
