[vcf-midatlantic] Applesoft game programming
Evan Koblentz
evan at vcfed.org
Sat Mar 4 02:22:31 EST 2017
I had an idea for a game. You'd use the joystick to control the physical
Lego robot against on-screen challenges such as places you must hit and
other places (evil robots) you must not hit, within a certain time, in
order to win. There would be penalties for going out-of-bounds
(colliding with the square around the screen).
I never wrote a BASIC game. This is a first for me.
I figure it's a good idea to start by determining some (ahem) "basic"
concepts. After all I'm using the extent of 7th-grade formal programming
education combined with 30 more years of brainpower + improved
understanding of programming logic.
Starting by keeping it simple: sticking with Applesoft's lo-res mode.
I already knew the screen is 0 through 39 horizontally/vertically
(40x40) in lo-res mode. And I knew the joystick goes 0-255 each way.
So, I figured 256/40 is 6.4, so if I divide the status of paddle 0 or 1
by 6.4 then I can say that's my plot point, right? Time for a science
experiment...
I came up with this:
10 X=PDL(0) : Y=PDL(1)
20 X=X/6.4 : Y=Y/6.4
Then I realized some positions would give me remainders. No good.
Googled for how to round off numbers and discovered Applesoft's INT
command. Also found a tip explaining that INT rounds off * no matter
what the decimal may be *, so the trick is to always add 0.5 before
doing the INT function.
Okay, that makes sense.
20 X=X/6.4 : X=X+0.5
30 Y=Y/6.4 : Y=Y+0.5
40 PRINT INT(X), PRINT INT(Y) : REM (so I get numeric confirmation in
the bottom text area of the screen)
50 GR:COLOR=1
60 PLOT X,Y
70 GOTO 10
This worked fine going up and left, but not when going down and right.
When I moved the joystick all the way down, the plot point turned into
an exclamation mark. When I moved it all the way right, the computer
beeped and said ILLEGAL QUANTITY ERROR IN 60.
I have some vague ideas of what caused this, but my instinct was to fix
it this way:
Ran it that way. Holy moly, it worked!
Thus the full code for my little experiment:
50 GR:COLOR=1
60 IF X>39 THEN X=39
70 IF Y>39 THEN Y=39
80 PLOT X,Y
90 GOTO 10
Now I can move a plot point around the screen by using the joystick and
without having to redraw a black point over the previous point each time.
Then I had an epiphany... drum roll please...
I ACCIDENTALLY JUST PROGRAMMED MY FIRST SPRITE!
Cool.
As I posted a few weeks ago when making the Lego robot code work, you
guys can tease me if you like :) but this is a milestone. I stumbled
onto how to code a sprite in BASIC. Granted, it's only lo-res graphics,
but I would think the same exact method should work in hi-res graphics
mode. Also some things aren't perfect -- when I run the program without
touching the centered joystick, it reports a plot position of 18,23 --
so I'll experiment with the physical trim knobs.
Low-quality video (to accompany lo-res graphics...) is here:
http://www.snarc.net/EK_first_sprite.mp4
(It plays fine in VLC but appeared too tall in the default Linux Mint
player.)
_______________________________
Evan Koblentz, director
Vintage Computer Federation
a 501(c)3 educational non-profit
evan at vcfed.org
(646) 546-9999
www.vcfed.org
facebook.com/vcfederation
twitter.com/vcfederation
