[vcf-midatlantic] OT: Video Capture
Systems Glitch
systems.glitch at gmail.com
Mon Mar 6 21:32:19 EST 2017
We used one of the $150-250 range boxes at work to record presentations from usergroups. It worked fine and captured at full 1080p. Troll Amazon for a good deal that has verified purchase reviews. Then see if you can find the same item cheaper elsewhere.
Thanks,
Jonathan
On Mon, 6 Mar 2017 21:19:42 -0500
Dan Roganti via vcf-midatlantic <vcf-midatlantic at lists.vintagecomputerfederation.org> wrote:
> On Mon, Mar 6, 2017 at 8:24 PM, Chris Fala via vcf-midatlantic <
> > Can anyone recommend a way to take an HDMI video signal and convert it to
> > USB so it can be recorded on a computer? I found a device that does this
> > but it is around $300 and I wanted to find something cheaper.
> > Thanks,
> > Chris F.
> I haven't tried, but I always wanted to find out how good are these hdmi
> recorders
> with the online broadcasting craze, gamers are constantly uploading their
> tournaments in HD
> and so these recorders are becoming so popular
> they always have the same recorders which require a desktop to operate,
> just as the early generation recorders with only composite video,
> but this one even records hdmi to sd card without the need for a desktop
> and it's rather inexpensive at $150
> https://www.amazon.com/dp/B00B2IZ3B0/ref=psdc_6795230011_t2_B00840353W
